pre drill and countersink holes
Geppetto
18 mrt 2014
31
Hello All,
is there a rule to choose the right drill bit for pre drilling and countersink?
It's annoying to always put a drill bit in the drill, than swap it for the little
bit to countersink and than put the scew in.
So I wanted to by one of those bits that do both pre drilling and countersink in one,
however this means I would have to buy multiple size depending what crew I need,
so I was wondering if there is a rule for it or can I use a 3mm drill bit or something similar
everytime independently on the screw size?
Thanks
3.519
MaartenS
29 jul 2012
1.031
65
Omgeving Amersfoort
Hello All,
hey Gepetto...
in most cases i use the rule of thumb that i pre drill with a 1mm thinner than the screw.
so 8mm screw i predrill with 7mm
but it depends which material you are drilling and for what purpose. In MDF close to the edge i predrill with .5 smaller, in real wood making constructions the difference between screw and predrill bit can be bigger.
